While thumbing through the 200 to 300 pages of documentation on the CarSearch product (which mentions seven-character activate/deactivate codes) I also noticed numerous references to test tones being broadcast. I'm thinking the latest audio example mentioned with the sets of tones (from Jan. 2004) is from the old system referred to as CarSearch. This would explain why the CRC fails.
Scratch the above statement! This LoJack system is full of surprises.
This morning I captured the same identical three data bursts followed by the same three steady tones as was recorded back in 2004. So, apparently I was incorrect and the signal with the three tones is part of the LoJack system after all.
Every bit of the three data bursts I received this morning matched exactly the recording made in Jan. 2004 by another member of the forum. I was considering the possibility of these being activation signals until I noticed the three bursts matched exactly the signal received in 2004 bit for bit (same VRC, LRC, FCN Code, Address and CRC).
The only guess I have currently on what this signal may be used for is for some type of synchronization by the LoJack towers.
The following is a brief timeline showing where the three data bursts with accompanying tones occurred in relation to the normal data bursts I receive from two towers.
7:05:11 AM Tower 1 - regular burst
7:05:19 AM Tower 2 - regular burst
7:05:42 AM Data burst with three tones
7:06:15 AM Tower 1 - regular burst
7:06:32 AM Tower 2 - regular burst
7:06:34 AM Data burst with three tones
7:07-7:09 AM = Only regular tower bursts
7:09:27 AM Tower 1 - regular burst
7:09:35 AM Tower 2 - regular burst
7:09:53 AM Data burst with three tones
The three tones are as follows: 1st = 1800 Hz for approx. 2.687 seconds, 2nd = 1200 Hz for approx. 2.015 seconds and 3rd = 900 Hz with a possible second tone at 1500 Hz for approx. 2.015 seconds. There is actually a 4th quick burst of 1200 Hz for approx. 0.032 seconds at the end.
The three data bursts with tones all had a very strong signal strength and certainly originated from a tower rather than from a vehicle.
Shawn
