How To delete singke freequency from multy site system
ronenp
Hello
How Do i delete single frequency from a multy site system without deleting it from the other site ?
For example say site 3 have 866.2125 and site 7 had it also but the freeq on site 7 replaced to another one by the site manager sometime so i want to erase the not used one ...
trying to do so erased the freequency at all the sites and now im in a problem ... site 3 lost this freeq also ....
can someone tell me how to do it correct or is it a bug ?
NB of course that same freequency have same Channel (LCN) at all the sites because it is a NEtworked Multy site system .
Ronen;
Are you trying to delete a channel in Unitrunker?
If so ... try this.
Type [F]ind -> [C]hannel ... type in a valid LCN # (does not matter which) and press [Enter].
Press [Tab] or [Shift][Tab] until one of the menu items in the channel editor is highlight.
Now press [Shift][Tab] to move the cursor to the scrolling list of channels.
Use the [Up] and [Dn] arrows to navigate. Highlight the channel you want deleted.
Press [Tab].
Select [Del]ete.
This should delete only the channel highlight. The site number is in the left column. When editing a channel, the site number where the channel belongs is displayed in the top left corner of the channel edit panel just under the menu.
