How to determine th"A", "B" or "C" model of HT1000
n8bmb
I suspect the answer to the question is gonna be like "DUH"!, but how do you determine the "A", "B" or "C" model of the HT1000? Each model has slightly different capabilities and I need to know so I can program mine correctly without locking out the radio.
Dennis
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
When you look at the model number on the back of the ht1000 under the battery, the last two digits will be 'AN' 'BN' 'CN' or 'DN' the model number will start with the letter 'H' and be an alpha numeric sequence
n8bmb
That cannot be correct since the RSS gives only 3 "models" (or versions) that are supposedly available and a "D" is not mentioned. Unless the RSSI have is older and a "D" came out after the publication of my particular software. They only give an "A" "B" or "C" model (or maybe version) since I don't have the RSS page up right now. It did state that a certain few settings with the "A" model (version) are NOT compatable with the "B" or "C" and that programming the latter 2 with the settings from "A" could potentially lock up the radio. This is where I become confused since there is no "D" mentioned. I DO see what you refer to, but is there something else that would indicate the "version" I guess?
N4KVE
PALM BEACH, FLORIDA
Just like was stated. The "DN" is the most desirable version as it does the most & I believe will do narrow band. One of mine says H01RDC9AA3DN. GARY N4KVE
KG4INW
Midlothian, VA
For clarity, if you have the latest version of RSS, you can program any revision HT1000 (AN, BN, CN, or DN). The DN models were the last ones produced and are the most capable. I suppose model isn't a good name because it's actually just a revision designator and the entire string (as Gary above posted an example) is the model number and will ultimately determine what the radio is capable of.
There weren't that many distinct different HT1000s though. Mainly just 2 channel, 16 channel, DTMF keypad or not, etc. I hope this helps.
davidgcet
can you not read the radio and see what it says it is?
