To anyone looking to acquire commercial radio programming software:
Hi, If You Call Icom, Tech Support, At 1-800-253-1498, they can look that info up for you, just give them the entire model number including the -6 suffix, that identifies the split.
Thank you for your help. Unfortunately, things weren't quite that easy.
I called the number provided, and used option 2 for land-mobile radio technical support. I spoke with Fred.
Fred had never heard of an IC-F320S-6. Fred said that his computer agreed that no such model exists.
Fred also let me know that there is no method by which the band split may be determined from the serial number or from the FCC-ID.
Fred let me know the following:
- An IC-F320S-01 is a 136-155 MHz model
- An IC-F320S-02 is a 146-174 MHz model
- An IC-F320S-11 is a 136-155 MHz model
I provided Fred with the serial number from my IC-F320S-6. From that serial number, Fred was able to look up the specific details of this radio.
Fred let me know that the sticker on the bottom of my radio is actually supposed to read IC-F320S-02, and is thus a 146-174 MHz model.
