How to modify a Motorola TRS for rebanding in a Uniden XT Scanner
DJ88
Brick Twp., New Jersey
If I'm not mistaken, if the fourth number after the decimal point in all of the frequencies in a Motorola 800 MHz Type 2 trunk system is 5, the custom band plan isn't needed. In the video, the control channel that was rebanded had a 0 as the fourth number after the decimal point so the custom band plan WOULD apply. Someone correct me if I'm wrong.
Keith_W7KEW
California
Yes, If the changed control channel(s) or other trunked radio system channel(s) fourth number are 0 then you would need to reband the system. In this case 867.55000 was changed in the system to 852.55000 after rebanding.
