Baofeng How to Program an * talkgroup
davidqualls
When looking thru the frequency database, I find a few of the DMR listing show an * for the talk group. In my DM-1701 I have to give the Digital Contact a number, even If I do it manually thru a CSV it puts a 0 in the talk group.
What is the proper way to attack this?
David
davidqualls
Just for instance, this is the entry in the frequency database
453.51250 458.51250 WQBB947 RMCC 8
TG *
SL 1
Plumervile PDPolice DMR Law Dispatch
The TG is * where most of the entries look like this
TG 15
SL 1
Plumer PD TalkPolice Talk DMR Law Talk
The talk group is 15, which is what I would put in my Digital contacts as the Digital ID. If I use the import/export function and manually program my csv file with the * in the talkgroup, it defaults to 0. And I know that is not correct, but I have no Idea what to put in the TG.
GTR8000
NY/NJ Database Guy
BEE00
An asterisk in the RRDB listing indicates a wildcard. It means that the actual value wasn't identified and/or submitted. If your radio doesn't allow for wildcard values, you'll need to determine the TGID before you can program it.
davidqualls
Thanks for the Info, trial and error time.
chief21
Summer - Western NC; Winter - Tampa Bay FL
If you don't know the talkgroup, you can use the Digital Monitor (or similar) search feature of your radio, or perhaps a software application like DSD, to find the talkgroup ID. If your radio can't do that, you'll have to rely on local sources to determine the information. A request in the Arkansas forum here on RR might yield an answer for you.
