Howard County EDACS
jahnotis
Is anyone else having problem with LCN #6? I believe the frequency is 867.85. There's nothing on the channel and my scanner skips #6. Do I have the wrong frequency stored for #6?
jerk
jerkville
Are you receiving talk groups okay? The channel might not be used in normal rotation, and there is nothing wrong with that. If you are having trouble receiving talk groups or missing units talking back, then that might be a problem. But for nothing to be received on that channel does not mean something is wrong.
AL
zerobleu
Hamilton County, IN
Looking into your question I found FCC License WQDA709 For Howard County Indiana is showing there are nine frequencys that have been assigned to this license that are not in the Howard County RR Page and two that are on the page that are not on the license.. Looks like they're in the process of rebanding?
I dont know if they are listed in the FCC license in the order they should be used in a scanner maybe someone else can comment on that. I'm still fairly new to the community as well.
I hope someone else can use this and maybe answer your question.
jerk
jerkville
Yes- rebanding, YE indicates that this is most likely what is going on. I don't monitor the system, but it sounds like you have to figure out the new LCN order.
AL
jahnotis
867.85
AL
Yes I receive the talks groups. Thanks for the answer. I once tried to put another frequency in and it disturbed the entire grouping.
