HT1250 Audio Problem
KCOEM9108
Elgin, IL
I am programming several HT1250 Full Keypad, AAH25KDH9AA6AN, Radios. Read the radio to get the codepulg, built it, programmed 2 radios works great. Used the same codeplug made several programming changes for radios 3 & 4. Programmed radio 3 with the modified code plug and now I get audio out of both the remote mic and the speaker in the radio.
Thinking that it was maybe a radio issue I put this same codeplug in radio 2 and now I have the same issue with radio 2. I had saved the original programmed codeplug that I modified, dumped this back in to radio 2 and still have the audio issue. Took the original 'blank' codeplug that cam in the radio dumped it back in to radio 2, reread it and programmed 1 channel, tested to still have the audio issue.
Any ideas???
Using Pro CPS R06.12.02 Region AA
Thanks in advance.
KCOEM9108
Elgin, IL
I have tried 2 different RSM. They both work on my day to day HT1250 limited with out audio coming from the radio.
MTS2000des
5B2_BEE00 Czar
had the exact problem with an HT1250. Spent a couple hours on the phone with the RSC and ended up having to send mine in for a depot repair to get it right. Not sure what they did, but they replaced the main board. Mine was under warranty. No one could tell me what caused this problem. Mine was a VHF, current radio F/W and 2009 H/W build.
