HT1250 VHF
gsanjose
Could someone help me out. One of my friends a fire fighter brought me his radio(HT1250 VHF) with EEPRM CS ERROR on the screen. I tried to write to the radio and it won't go with a codeplug from one of the truck radio's which is the same mode #.
Could someone please help.
gary123
check the eeprom for a cold solder joint I have seen that before. If it is an earlier version with the battery replace the battery, put the unit in service mode, change any value (like tx power) by 1 and write the unit. then clone a good image.
SD70MAC
NC
ht1250
I have fixed many of these, 90% of them are due to some type programming error like using a USB programming cable,unplugging the cable before its done writing the radio. I have seen post that stated they wrote an saved codeplug from that radio,I have never got that to work. CPS R6.11.05 and above MOST of the time will fix it other times you have to use Lab software to fix it. If its a Fire Department owned radio send it to the dealer.
bezking
On the Road
Correct. Before you go taking the radio apart, read it with CPS R06.11.10. It will try to fix the corruption and rewrite the factory direct codeplug back into the radio.
