HT1250 with a twist
N1GTL
CT
OK, so I have nothing better to do with my time. Everyones HT1250 looks the same. Sure, there are yellow cases and even an occasional camouflage case. But how about a keypad with RED backlights? I was going to change the display to red also but the LED's are not the same.
It's kind of tough to get a good photo but you get the idea....
N1GTL
CT
I have not tried other colors, no. Blue is available. I need to find the different red LED's that light the LCD display.
Skypilot007
Medford, NJ
I like that. I might just try that with a mcs2000 III here that needs the backlights fixed. Thanks for the idea.
62Truck
Ordinary Subscriber
Uranus
Interesting, have any info on where you got the LEDS from and how you did it
N1GTL
CT
LED's are from NTE Electronics, Bloomfield, NJ. That's the name on the package. I got them at a local electronics store. I still have not had time to look for the other ones that light the display.
There are 6 surface mounted LED's on the board that is behind the keypad. Simply remove the old and put in the new. Don't forget polarity.
N1GTL
CT
I think they were $1.29 for 6. I have not checked to see if the CDM uses the same LEDs as the HT1250s
