HT750 Programming Mode
cpg178
Hi,
I have a HT750 4ch UHF model I just got from ebay, i have the CPS and the cable but I can not find any info online how to put the radio into programming mode?
Yeah, radio on, cable connected, RIB turned on (If you are using a RIB), make sure the correct COM port is selected. Hit read radio and it'll do the rest.
BlueDevil
WA
Depending on the Type/Brand of cable you may run into significant issues with finding the correct driver if it is a USB Programming Cable.
K2NEC
NA
Check in your device manager to make sure the cable is recognized if the radio won't read
