HT750
Rudy3145
New York
Can all HT750 decode Quick Call II ? I'm not seeing the option in signaling for this one HT750 portable, and I've seen it in other HT750's
Lakes_Region_Comms
I’m only 14
In the personality that you want to have selective call paging on, go to the signalling tab, make sure quick call 1 (or 2 what ever one is there) is enabled in the Rx system window. The go to the Signalling squelch window and select "and". This will cause the HT750 to mute on this personality until the tones are activated. The monitor button should also serve as a "reset" button when this function is enabled.
Lakes_Region_Comms
I’m only 14
Also, put in the proper tone sets, and PL or DPL codes, unless its a CSQ channel. Set the channel to RX only too if you transmit on that channel, the page might not go through, Make sure to take the channel out of the scan list if its in it, or it wont alert properly
Rudy3145
New York
I'm familiar with that. in this HT750, I don't even see an option for QCII under signaling, just MDC. I'm thinking this model doesn't support QC
