I 465 mile marker/exit map?
IndyRick
Indianapolis
Hi, gang, I apologize if this is slightly off topic...I'm looking for a 465 mile marker map to print off and hang in my shack, so when I'm listening to my scanner I can quickly reference where an incident is. I have googled and found a few text lists, but I'm looking for a map. Anyone know where I can find one?
Thanks,
Rick N9GSU
Anon6083
The INDOT map for the Indianapolis area has the exit numbers that directly correspond to the closest mile marker, so this will at least let you determine the relative location of a given mile marker between two exits:
http://www.in.gov/indot/files/IndyMap.pdf
W9NES
Indianapolis,Indiana
IndyRick, Many years back Indiana State Police and the Marion County Sheriff's Depatment put out the milemaker charts. I have a ISP Milemarker Chart for across the state and also I-465. I have these in the Northwest Commuications Center.I will look around for you and if I do have any extra copies I will make sure you get a copy of both the statewide and I-465.milemarker charts.
AK9R
Staff member
Super Moderator
Central Indiana
In addition to the direct link to a current PDF map of the Indianapolis highways and exit numbers, the following page on the INDOT web site, has links to PDF maps for every major city in Indiana:
INDOT: Maps of Major Indiana Cities
The official Indiana highway map can be downloaded as a PDF from here:
http://www.in.gov/indot/files/StateTransportationMap.pdf
The Interchange Book PDF files, which provide a detailed look at every interchange in state, can be found here:
INDOT: Interchange Book
One of those interchange maps I looked at was just revised yesterday, so it appears that INDOT is keeping their on-line files pretty current.
W9NES
IndyRick, I will make a copy for you of the offical Indaina State Police I-465 Milemarker locator that is till vaild.This does contain all the milemarker and exit numbers that you need around I-465 in Indianapolis.
W9NES
IndyRick, I do have 2 copies of the offical Indiana State Police exit identification by mile-marker for you. One is the map for I-465 and other one is for I-65 and I -70 the north and south split downtown.I will get these to you ASAP. Thank You.
W9NES
IndtRick, I have 2 milemarker charts for you.These came from The Indiana State Police.Will try to meet you this week to get them to you asap.Thank You.
