I cannot stand Halton EDACS system because...
EJB
20 + year membership
Downtown Hamilton
I haven't successfully monitored this system in ages.
I can get the Burlington Tower well enough, 2-4 bars on my 296, the freqs are listed in the LCN order, it is set in EDACS wide set to AFS.
I get activity, t/g's show up but very rarely do I get anything other than the wonderful EDACs beep beep beep
There is def activity on the v/channels but rarely do the tags and voice comms go 2gether.
I tried this out in Aldershot the other week and the same thing.
TIA, would appreciate some help.
Eric
exkalibur
York, Ontario
I remember someone talking awhile back about there being special patch talkgroups or something which make the Halton system a royal pain to listen to. I never listen to Halton, so I have no idea about the system or any of the channels/patches, but maybe that's what is causing the issue?...Aside from the crappy signal strength you're seeing. 2 to 4 bars should be enough to hear no problem, I can hear Toronto Police when the signal is down to around 1 bar.
ocscan
Ottawa, On
Are you seeing valid talkgroups show on your display...if so problem might be in your scanner programming? EDACS must be programmed in in the proper LCN order.
EJB
Downtown Hamilton
It is in the order listed on this site for the Burlington site. It was programmed properly.
Right now I am getting this tower at 2-3 bars from Toronto and I am always getting the t/g's and OCASIONALLY actually getting lucky enough to get voice transmissions (as we speak I am).
As I mentioned in my earlier post I have never had much luck with EDACS systems.
My 296, for whatever reason does a horsesh*t job on these.
Same went for Toronto's EMS EDACS.
I am off to Burlington 2day. I will play around with it and see how it goes.
If you want I'd email my ARC250 file and perhaps you can find that I am doing something wrong.
E
jellotor
Hamilton, ON
Eric, one thing I forgot to ask...is it programmed as EDACS wide or narrow? It should be narrow, I believe. That may be the cause of some of your EDACS headaches.
rhutch
Ontario
I monitor it all the time while passing through with no problem (396). Try EDAC's narrow like Jellotor said.
Chrome69
Ontario, Canada
Yes i agree thats what i have it set to, but most of the time i get the patch groups only... After i get my 330T i will try and do a system search and see what we find maybe were missing a few TG's? Since i am close to the board of Mississauga and Oakville I get strong signal... I will also turn it on my feed now for the afternoon for anyone to listen to...
EJB
Downtown Hamilton
Guys: I tried narrow. On narrow it switches the mode from FM to NFM.
I also havent heard anything on it. When I lock onto the control channel on EDACS Narrow, nothing, no ids pop up.
On EDACS Wide there is sparadic action.
I can sometimes hear what is going on but most of the time nada. The signal was good in the Brant/QEW area but really weak in the Aldershot area.
Honestly I am at a loss; I have always hated EDACS systems; I 'd probably not give a rat ass about Halton but if there is a major incident it would be nice if an analog system that should work would work.
This is the orde rof the frequencies (I left channel 901, bank 10 blank):
0861.2625
0861.5125
0861.7625
0862.0125
0859.3625
0857.1125
It is set to the following:
Delay=no.
Record is 'checked'
Icall is set to On.
and the ID format is AFS.
Both the activity ID and
Emergency Alt are also checked.
EJB
Downtown Hamilton
Still the same ol' bullsh*t.
I am in the middle of the city of Burlington.
On EDACS narrow I cannot hear a thing.
On EDACS wide I can get the tower well but cannot normally track any talkgroups.
jellotor
Hamilton, ON
I guess I'll have to send you my ARC250 file at some point, Eric. Works fine with either of my 250Ds.
EJB
Downtown Hamilton
Pointed in the right direction and it works now.
Thanks to Rainbow 6 I got this system working!
I had the freqs in the correct order but I skipped a channel I.E. I used channel 901 instead of 900, a deference to my Pro 93 days (skip the 1st channel).
Thanks 2 all those who helped!
E
motomeso
Ontario
Does this mean you Love the Halton Edacs System again. :)
xml
The system makes excessive use of patches to not only interconnect the sites but to conveniently confuse the heck of your scanners. On a system radio, these patches are seamless.
jellotor
Hamilton, ON
On a scanner with the patches programmed it's relatively seamless too. I was missing parts of some conversations at one point...programmed a few of the patches I had forgotten and was off and running.
niko
what exactly does the term patches mean, and how can i configure my pro-94 to pickup halton(oakville) edacs, because its not working!!!
can that file u guys have be uploaded to mine too?
