I got a GTR8000 basic radio,need some helps
loki7777
My friend gave me a GTR8000 basic radio,but the tx is failed,receiver is normal. Hardware test shows the exciter failed and TX Synthesizer locked. as shown in the picture. I need some helps. Thanks!
a417
I need a friend who can give me a GTR8000...sheesh.
Usually...Green is good, red is bad.
an unlocked TX synthesizer would be bad. Address the failed issues first.
I'll take it you don't have a lot of experience with GTR series base stations, or repeater grade hardware in general? Do you know what an exiter is? Do you know why that one has failed?
KevinC
Other
Super Moderator
Home
Thinking about the alarms a little more, it may be set for trunking and simulcast. It doesn't appear to have the the option board so no internal reference oscillator and without that it won’t work.
loki7777
yes. It has been set for trunking. Is there any way to turn it to a connventional repeater?
KevinC
Other
Super Moderator
Home
You will need to SWDL to a conventional BR. And without that option board or an external reference it won't work.
jeepsandradios
East of the Mississippi
+1 on a friend giving me a base radio....heck I work in the field and cant get one....
Anyway as said you need the SWDL to change it to a BR. If you plan to use this narrow band you need old swdl as anything after 7.18 will only allow narrow band programming. You can use old swdl, set for wide and program then upgrade.
As reference you exciter is faileld becasue it has no 1pps signal. Lan failed as there is no cable plugged into the network jack. The Infastructure link is failed as its not talking to a comparator.
rr60
Asking for a friend, from one of these?
loki7777
Thanks! I found the reason. no transceiver option card.
intuity
Dallas, TX
Just to clarify, a short search on eBay brings back an average sale price of $5-7k for the GTR8000, not including controllers, etc. Like I said, either deeper pockets than sense, or we're about to find ourselves in the middle of the proverbial pasture.... :ROFLMAO:
