I have a odd ? Or not
ProLaw1
So here’s my ? Is it possible that a Uniden BCD325p2 could lose sensitivity over time, as in 4 years of moderate use, has never left house or been abused,just curious TIA
W4EMS
NoVA
Any nearby transmitters? Nearby meaning antennas in close proximity, same tower/mast.?
ProLaw1
How is the weather channel reception?
Have not tried that one yet to see what’s happening,just FYI I have 2 of these siting next to each other,and both are programmed the same and the newer seems to be working a lot better than the older one, I get full bars On the display from the p25 site I’m monitoring from the newer scanner and 3 to no bars on the older scanner
hiegtx
Dallas, TX
Try swapping the antennas between the two scanners. While you might not see any physical damage, like the pin on the connector, it's at least possible that there could be damage inside the antenna, which is not visible due to the rubber covering.
Have you also verified that the squelch settings on the two are the same, and that on the one that seems to be somewhat deaf, that the attenuator has not been turned on by accident"
ProLaw1
is attenuation on, on one of them ?
That’s off on both scanners
squelch is set to 3,attenuator is off, and just to be on the safe side I went ahead and ordered a Remtronix REM 800B replacement antenna off eBay
hiegtx
Dallas, TX
I still would try swapping antennas between the two. If the "problem" switches scanners along with the antennas, then you know it's an antenna, not a scanner, problem, and you've already got a replacement on order.
  • Like
Reactions: wtp
n1chu
Farmington, Connecticut
If, after you’ve followed all good previous advice, the scanner still performs poorly, send it in to Uniden for repair. Hopefully it’s still under warrenty. Call first for an RMA.
ProLaw1
Yep I tried it and a little improvement, but instead of showing 0 bars it was showing intermittently 1 to 3 bars now
ProLaw1
Not under warranty anymore,it’s about 4 years old, it’s strange because the scanner seems to work great otherwise
buddrousa
Without having a SERVICE MONITOR the only way to test is to share the same antenna at the same time with both scanners programmed the same. You also could have 1 scanner interfering with the other scanner.
wtp
Port Charlotte FL
also have you switched the radio around on their spots ?
my wife's 396XT was sounding horrible, so i moved it 4 inches, and it went from horrible, to, i can listen to that.
INCHES MATTER.
