Sentinel: I have the Uniden Sentinel software working with Linux Mint (LMDE 5)
radiochuck
Traffic Reporter
Phoenix, AZ
Yes, just paste the code block into the terminal window and hit enter. I tried it several times on Linux Mint, and it just resulted in many, many errors (404 not found, failure to fetch, and quite a few others) and the process aborted with neither WINE nor Sentinel being installed.
The link in the code block for Sentinel is correct for the current version.
Let us know if it works for you.
I sure will. Thank you for the help.
radiochuck
Traffic Reporter
Phoenix, AZ
Unfortunately no. The install seemed to go okay, with a few occasional hiccups that I thought it had worked through on its own. When all was finished, I connected the radio and set the drive config to Floppy Disk, but when I attempted to run Sentinel, it resulted in the following error log...
Unhandled exception: 0xe0434f4d in 32-bit code (0x7b010be6).
Register dump:
CS:0023 SS:002b DS:002b ES:002b FS:006b GS:0063
EIP:7b010be6 ESP:008ae334 EBP:008ae3a8 EFLAGS:00000297( - -- I S -A-P-C)
EAX:008ae340 EBX:00000001 ECX:80070057 EDX:008ae3e4
ESI:e0434f4d EDI:e0434f4d
Stack dump:
0x008ae334: 79e786aa 017fdc30 017fdc30 e0434f4d
0x008ae344: 00000001 00000000 7b010be6 00000001
0x008ae354: 80070057 790c2000 00000036 00000006
0x008ae364: 790fabcc 79e7be3f e0434f4d 008ae3e4
0x008ae374: 790c2000 02000036 008ae390 79e814da
0x008ae384: 008ae39c 02000036 00000001 008ae40c
Backtrace:
=>0 0x7b010be6 EntryPoint+0xffffffff() in kernelbase (0x008ae3a8)
1 0x79f97065 EntryPoint+0xf6538() in mscorwks (0x008ae40c)
2 0x7a0945a4 EntryPoint+0x1f3a77() in mscorwks (0x008ae4d0)
0x7b010be6 EntryPoint+0xffffffff in kernelbase: subl $4,%esp
Modules:
Module Address Debug info Name (48 modules)
PE 400000- 6a0000 Deferred bcdx36hp_sentinel
PE 1030000- 1496000 Deferred ole32
PE 38d0000- 3d75000 Deferred comctl32
PE 3f50000- 3f7a000 Deferred zlib1
PE 3f80000- 4c06000 Deferred system.windows.forms.ni
PE 4d90000- 4f21000 Deferred gdiplus
PE 4ff0000- 5336000 Deferred windowscodecs
PE 5e380000-5e409000 Deferred diasymreader
PE 60000000-60008000 Deferred accessibility
PE 60340000-60348000 Deferred culture
PE 61740000-61832000 Deferred advapi32
PE 62fc0000-631d3000 Deferred rpcrt4
PE 63480000-6349b000 Deferred version
PE 63bc0000-63c04000 Deferred shcore
PE 641f0000-6420d000 Deferred shfusion
PE 64220000-64238000 Deferred shfusres
PE 64890000-648f2000 Deferred system.configuration
PE 64a40000-64b29000 Deferred shlwapi
PE 64ec0000-652b9000 Deferred oleaut32
PE 66240000-66288000 Deferred bcrypt
PE 68500000-68640000 Deferred combase
PE 68700000-68788000 Deferred uxtheme
PE 69940000-699a6000 Deferred propsys
PE 69be0000-6a148000 Deferred system.xml.ni
PE 6a280000-6a4cd000 Deferred msvcrt
PE 6b840000-6b8db000 Deferred msvcr80
PE 6bc00000-6bc99000 Deferred sechost
PE 6bcc0000-6be60000 Deferred setupapi
PE 6c9c0000-6cf59000 Deferred gdi32
PE 6d300000-6d30d000 Deferred shfolder
PE 6d640000-6d646000 Deferred fusion
PE 6e8c0000-6eb79000 Deferred crypt32
PE 6ed00000-6f389000 Deferred user32
PE 6fa80000-6fc82000 Deferred dbghelp
PE 6fe40000-6fedb000 Deferred rsaenh
PE 70b40000-70df9000 Deferred ucrtbase
PE 71200000-71251000 Deferred imm32
PE 79000000-79045000 Deferred mscoree
PE 79060000-790b3000 Deferred mscorjit
PE 790c0000-79ba8000 Deferred mscorlib.ni
PE 79e70000-7a3d1000 Export mscorwks
PE 7a440000-7abfe000 Deferred system.ni
PE 7ade0000-7af74000 Export system.drawing.ni
PE 7b000000-7b348000 Dwarf kernelbase
PE 7b600000-7b929000 Deferred kernel32
PE 7bc00000-7bea9000 Deferred ntdll
PE 7ec80000-7ec84000 Deferred winex11
PE 7ed30000-7f602000 Deferred shell32
Threads:
process tid prio (all id:s are in hex)
00000038 services.exe
0000003c 0
00000040 0
0000004c 0
0000006c 0
00000078 0
0000008c 0
000000a4 0
000000b0 0
000000dc 0
000000f4 0
00000120 0
00000044 svchost.exe
00000048 0
00000054 0
00000058 0
0000005c winedevice.exe
00000060 0
00000070 0
00000074 0
0000007c 0
00000064 explorer.exe
00000068 0
00000088 0
000000b4 0
00000080 plugplay.exe
00000084 0
00000090 0
00000094 0
00000098 0
000000bc 0
0000009c winedevice.exe
000000a0 0
000000a8 0
000000ac 0
000000b8 0
000000cc 0
000000d4 mscorsvw.exe
000000d8 0
000000e0 0
000000e4 0
000000e8 0
000000ec rpcss.exe
000000f0 0
000000f8 0
000000fc 0
00000100 0
00000104 0
00000108 0
00000110 (D) C:\Program Files\Uniden\BCDx36HP Sentinel\BCDx36HP_Sentinel.exe
00000114 0 <==
00000118 0
0000011c 2
0000012c 0
System information:
Wine build: wine-6.0.3 (Ubuntu 6.0.3~repack-1)
Platform: i386
Version: Windows 7
Host system: Linux
Host version: 5.15.0-79-generic
belvdr
No longer interested in living
Typically, when these errors occur, it's because you have a 64-bit wine prefix. Make sure to create a 32-bit prefix. Removing ~/.wine and running:
Code:
WINEARCH=win32 winecfg
will create it. Just exit winecfg when it starts. Beware, this will delete any wine programs you have installed in that wine prefix.
Sometimes, having the incorrect .NET framework will cause it too.
radiochuck
Traffic Reporter
Phoenix, AZ
Code:
I wonder if there's any way to start over, then modify the install code to force the win32 version?? Linux is very new to me.
belvdr
To start over with wine, just delete the wine prefix, typically ~/.wine. As your normal user, not sudo or root:
Code:
rm -fr ~/.wine
That removes all the programs and data in that wine prefix. You don't need to modify any install code.
radiochuck
Traffic Reporter
Phoenix, AZ
Code:
rm -fr ~/.wine
Thank you. I'll give that a try. The install code did include the line "WINEARCH=win32 winecfg", so I'm not sure that's my issue, but I'll see what I can do with the info you gave.
belvdr
Did you run that command first? After doing that, and unless you ran another WINEARCH, you should be fine to exclude it. It may be the wrong .NET framework too. I forget which one I installed, but thought it was 4.8 and I used winetricks after running the winecfg command you mentioned:
Code:
winetricks dotnet48
radiochuck
Traffic Reporter
Phoenix, AZ
Code:
winetricks dotnet48
I may be in over my head on this one. All of the code is what's in the link that fxdscon posted above. You can see all of the commands and order by checking out that link. I'm sorry I'm not able to better tell you what I did. I'm not a Linux guy and I'm just a little disoriented. I appreciate all of the help. though.
