FLA727
I recently picked up the MAX 2000 antenna for my base setup. I finally got it connected and in the air; currently about 23’ from ground to antenna base (I need an extra set of hands to raise it up to 30’). I am using about a 65’ run of LMR 400 and the antenna is grounded to my home service ground.
On the initial SWR test I was getting around 2.0 – 2.3. I was under the impression based on the antenna documentation the this was a great 11 meter out of the box antenna so I started searching only to find a lot of conflicting information.
I have read that the 3rd section (top) was recently (Jan 2020) shortened for shipping compliance by Solarcon and most of the post I have found are fairly old.
I have seen on a variety or boards people have replaced the 3rd section with a 102” whip but there is still a lot of conflicting opinions. I believe that I will need to lower the antenna and actually measure the 3rd section so that I can determine if I have an older version or the newer shorter one. I believe it needs to be 96.5” but need to look it up.
1. If it is the proper length, is this a matter of just adjusting the tuning rings?
2. Is there any documentation on the tuning rings so that I know how to adjust them? The instructions do not have any good details.
3. If it is not the proper length, can the 102” whip be used (trimmed or not trimmed)?
4. Would adding the Antron GPK-1 ground plane kit help the overall situation and performance?
5. Should I count as a loss and get a different antenna?
I have also read that you could add a 10” antenna riser but that seems to me that it would be too much additional length since supposedly the 3rd section was only shortened by about 1.18” (3 cm).
Again, there are so many opinions from none of the changes are true to almost that the antenna is worthless for 11 meter.
Unfortunately this entire project has been a whole lot more complicated than I originally planned on.
