Papa0s0
Hi, I get two of this radios and a got a question, in the manufacturer description said " Frequency range. IC-F50 IC-F60, 136-174 MHz 400-470 MHz 450-512 MHz (U.S.A.) 450-520 MHz (General)" but if when try a frequency in the UHF band 462 MHz the channel name stay binking and can't transmit. What I'm doing wrong?
If you have the IC-F50, it's a VHF radio only. Frequency coverage is 136-174.
If you have the IC-F60, it's a UHF radio only. Frequency coverage will depend on the -exact- model you have.
Since all 3 UHF versions will cover 462MHz, is it possible you actually have an IC-F50 VHF model? If so, you will not be able to program it for UHF frequencies.
Also, are you using the programming software to do this?
12dbsinad
Flashing display = VCO out of lock.
1) The frequencies entered are not within the frequency range of your particular radio.
2) There is a problem with the radio. I've seen some get into the adjust software and really mess things up.
I'd be willing to bet you have the wrong band split radio, however.
Papa0s0
Thanks both of you for the promptly answers. And yes is IC- F50. I will have to use MURS frequencies.
