Icom F40GT-1
wgonzalez
I have an IC-F40GT-1. I am trying to find out if it can be changed from 400-430 mhz to the 460 mhz range. Any help greatly appreciated.
rescuecomm
Travelers Rest, SC
I looked at doing this several years ago. The VCO board has about 8 chip capacitors that need to be changed and I was unable to locate any from the usual supply houses. I gave one radio away and used the case off the other for parts. The radio will go up to 434.000 or so as is.
Bob
blix662000
Hello all I just acquired ic-f40gt-1. Is it possible to change it to 450Mhz to 470Mhz. If so can some one point me in the right direction.. Thanks
cabletech
Puget Sound
If the radio band split stops at 450, then there is no easy or cost effective way to make it go to 470.
As was said in the post above, it will only go about 1.5 mz above 450.
