ICOM FR5000 / FR6000 DTMF Decode
brushfire21
NorCal - Napa Valley
I am trying to get an Icom FR series repeater to open/close IO-15 AUX-1 output contact or get it to respond and I must be missing something. Am hoping someone can help here as I am sure its something simple I have overlooked.
Under DTMF decode menu I have the First decode slot #1 setup for 1234 (DTMF decode) and the action for that DTMF code set for AUX-1 / On and then for the second decode slot #2 setup for 5678 (dtmf decode) and the action for the DTMF code set for AUX-1 / off. Under external I/O I have I/O-15 set to AUX-1 active High.
After cloning the repeater, I/O Pin 15 is low at 0-volts now (was at 5v when it was set for active low). But when I key the repeater and put the DTMF codes into it, Aux 1 / IO-15 does not change state. What have I missed? Thanks all in advance.
