ICOM FR6000 analog trunking?
ve2jka
Montreal
Hi, I have a FR6000 with 2 radios modules and the trunking card (which works for digital trunking) ...I would like to ad an external trunking (analog) controller as well. Any info would be greatly appreciated.
tc792
West Central Texas
I'm no trunking expert. But, I feel confident in saying that you with the current hardware Icom has you will not be able to do digital and analog trunking with the same equipment. The Icom board is only for digital trunking and requires dedicated transmitters. Also, for analog trunking you will need more than two modules.
The two system types work completely different.
RADIOGUY2002
Chicago Burbs
Ditto
I'm pretty sure that is the case, check with the dealer and Icom Tech Support. The IC-F5000/6000 was designed for digital purposes and digital trunking,
