Icom ic 221s programming and squelch noises
electric2u
Charlevoix
I have a Icom ic 221s programming it with cs-f100s. When I turn the radio on it's like the squelch is turned down all the way down(making squelch noises), but I can transmit though it with another radio, so I know the radio can receive. I'm missing something in the setting. I played around with the squelch in the program it will not even receive also not squelching. Need help
Kevin
electric2u
Charlevoix
I did check that and put 50 on squelch did not help. It’s loud squelch with receive transmission or put in 60, silent and no receive transmission.
jeepsandradios
East of the Mississippi
Well I alwasy start at 120. If 60 clears up the noise and your not receiving then either your too far away from the signal or you have something else wrong.
electric2u
Charlevoix
I think something else is wrong. Do you think that the usb cable was from a ic 221 vhf radio and I’m using it on a 221s uhf radio is the problem? I know the program is f100s
