PropwashPete
Hi everyone. I am brand new to these forums, so my question my be better asked in another forum, but ya gotta start somewhere.
I have an ICOM IC-A22 handheld transceiver that I want to use as my primary communications radio on my Experimental aircraft. The radio seems to work fine as a handheld, using the built in speaker and microphone. The problem starts when I try to use it with my Telex Status 50 headset. I am using the recommended headset adapter (OPC-499) but the volume through the earphones is very very low. In flight you can not hear anything at all. Also, though the push-to-talk switch seems to trigger the transmitter, the mike does not modulate. No voice is heard by others although they can hear the mike "click" when I press the PTT switch.
Has anyone ever run into this type problem before? ICOM support does not seem to have a clue.
Thanks,
Propwash Pete
Thanks,
Propwash Pete
