ID conversion cross reference
nycirnwrkr
Woodstock,NY
Since they are rebanding in Ulster, I have encountered a few not too many tags that on my chart dont exist. looked on NF2G not there either. Sams point has a 5 decimal id tag
Illinois had 1 or 2 tags on it too. where would one find an updated list since the reband?
D
DaveNF2G
Guest
Are you hearing traffic on these talkgroups (I assume that's what you mean by "tags"), or just catching them in a software log? If the latter, then they are probably errors.
nycirnwrkr
Woodstock,NY
AFS ID Tags
Dave look at poughkeepsie PD AFS Numbers, i have all the PD typed in for that tower, but I get 01-100 (not on your List) . 01-100 sounds like a dispatch. Same for Sam's point but a 5 digit Decimal tag.
I'm catching them with my 396 on ID Search mode, Which i hope to goto ID Scan mode once i get all the PD and FD's typed in.
hoping to get all of them with in a 35-40 mile radious of my home in woodstock ny
Spec
South Carolina
5 digit ??
Are they possible "LID's" ? What are the numbers you're getting ?
Spec
nycirnwrkr
Woodstock,NY
a what?
LID? i wasnt quick enough on the button to catch it, but have seen it several times. will post when i get it
Spec
South Carolina
Lid
Depending on what brand and model radio you are searching with you may be finding a LID. They are used often on the Illinois Twr. An example would be when HQ's wants to talk with a single unit without all the other units hearing.
Spec
nycirnwrkr
Woodstock,NY
5 digit tag id
here is what i got off of the Illinois tower 00224,00866,00758. These are displayed exactly as typed, no dashes no nothing....exactly as you see it now for all 3 individually
pro92b
Mutated Member
LID = logical ID, the individual identifier for each radio on the system. LID's are used for private calls between one radio and another. In effect they form a temporary talkgroup that is deleted once the conversation is over. The three numbers you posted are all assigned to radios in the city public works department. They do use private calls (I-calls) extensively. Evidently you have this feature turned on for ID Search.
01-100 is in the public works group for the town of Pok. I have never logged this particular ID and it may be an error either in the radio decoding it or you may have transcribed it wrong. I monitor Illinois often enough that it should be in the log if it was active.
nycirnwrkr
Woodstock,NY
EFJ/Transcrypt Trunked Radio Systems are programed with what type of system?
I am trying to get all the Alamo ambulances programed in?
pro92b
Mutated Member
Alamo is on many LTR systems throughout the tri-county area.
