If you look at the history of amateur bands, you will see that we have gained much more that we have lost.
Losses:
11 meters (yes, it was a ham band before CB)
220-222Mhz (loss due to non-use)
Gains:
60 Meters
30 Meters
17 Meters
12 Meters
33 CM (902-928Mhz)
Other additions are possible in the near future.
I would have to disagree with that.
The biggest ham spectrum loss of all, at one time ham radio had EVERY frequency above 1500 kHz (200 meters). It was thought frequencies above that were useless, so give them to the hams. During this time and on these "useless" frequencies people were "experimenting" as high as 1.25 meters. And in 1927 we lost almost all of that spectrum. After that it is hard to say we gained more than we lost.
But lets look only at the time after WW II.
WW II caused some shakeups, mostly because of technology developed during the war and the forced changes of those techs.
We lost all bands for the duration of WW II, and did not get most of them back until the war had been over almost a year. 2.5 meters became the Aviation VHF band. 160 meters became the realm of LORAN. 160 meters did not fully come back to hams for decades.
We lost 5 meters and 2.5 meters, but gained 6 and 2 meters for those.
In 1947 we lost the top 300 kHz of 10 meters and the top 50 kHz of 20 meters. We gained 15 meters and 11 meters.
In 1958 we lost 11 meters.
Then in the 80's we got the WARC bands (30, 17, 12 meters) and 33 cm.
In 1988 we lost 2 MHz of 1.25 meters.
Losses, since WW II (based on the last pre-war 1941 allocations) we have lost:
85 kHz at the bottom end of 160 meters (originally 1715 - 2000 kHz)
The top 50 kHz of 20 meters (originally 14000 - 14400 kHz)G
Gained and then lost 270 kHz on 11 meters (26960 - 27230 kHz)
300 kHz on 10 meters (29700 - 30000 kHz)
4 MHz on 5 meters (56 - 60 MHz)
4 MHz on 2.5 meters (112 - 116 MHz)
At that time 1.25 meters was 6 MHz wide, 224 - 230 MHz, that has all changed, so call it 6 MHz loss.
And hams had access to all frequencies 300 MHz and up as an "Experimental" region with 400 - 401 MHz as an exclusive allocation.
So not counting the 300 MHz and up region, since the end of WW II we have lost 14.705 MHz of spectrum below 300 MHz (or 14435 kHz if you null the gain and loss of 11 meters), and huge chunks above 300 MHz.
Gains, in the same time period as these losses, we have gained:
14 kHz with the 5 channelized 2.8 kHz frequencies on 60 meters
50 kHz on 30 meters (10100 - 10150 kHz)
100 kHz in 17 meters (18068 - 18168 kHz)
450 kHz in 15 meters (21000 - 21450 kHz)
100 kHz in 12 meters (24890 - 24990 kHz)
4 MHz in 6 meters (50.0 - 54.0 MHz)
4 MHz in 2 meters (144.0 - 148.0 MHz)
4 MHz net in 1.25 meters (219 - 220 MHz and 222 - 225 MHz)
Or 12.714 MHz of gained spectrum below 300 MHz. Above 300 MHz we gained exclusive allocations, but lost far more spectrum in shared allocation.
So, more spectrum lost than gained, since WW II.
T!
