Baofeng Imma newbie can I pick your mind for a min? 😅
ScStateSecured
Goose Creek
Hey tribe I’m In my first 7 months into amateur radio WSGZ372. & I just got my license..
What really turned me on to the whole community and culture. Well is the fact that one day cell phones Internet and every method of communication that modern day people use will be rendered useless at some point in time I believe that However, amateur ham radio will not as long as the human heart is beating and there’s a battery powered we will have communication. SOO
I’ve done a lot of research and I dedicate 2 to 3 hours every day just to focus on amateur radio.
My question is, how would I program an NAC Tone into a Baofeng 5RM MANUALLY?
My
EAFrizzle
Okay, from reading a few others posts, you want to know how to program a repeater tone. Press the green menu key, enter or scroll to #10. That is CTCSS recieve tone. 11 is DCS recieve code. 12 & 13 are for CTCSS and DCS transmit respectively.
a727469
Maine
Go to section 6.3 in the manual although it is listed wrong in the index
  • 5RM Manual.pdf
ScStateSecured
Goose Creek
OK, I may be. I may be slow slower than I thought when radio reference references input, would that be the frequency that I receive on or is that be the frequency that I transmit on
ScStateSecured
Goose Creek
Cause I’m manually having the program my 5RM so in order to program the two frequencies together, I have to start with one frequency which one do I wanna start with ? the input or the output frequency ? which one do I receive on the input or output cause then when I go back to program the other frequency, that would be the one that I transmit on
EAFrizzle
You program in the repeater output into your receive channel. Transmit frequency is determined by offset, also in the menu functions.
a727469
Maine
I might suggest a few things
Read the manual from cover to cover and then read it again. Mark areas you don’t understand.
If possible program through a computer using the CHIPS program.
Contact someone locally who has used radios on gmrs and let them help you. It is always better to talk this thing out with someone who has experience and could help with the areas you marked as not understanding.
Don’t give up..you will learn it eventually..as they say it is not rocket science😉🙂
Good luck!
K9KLC
Southwest, IL
Good luck!
Do you mean CHIRP? I'm not familiar with anything called CHIPS programming.
janeksp6
WprowadziƂem CHIRP ale system nie widzi pliku Przepraszam
janeksp6
SCStateSecure BawiƂem się w ręczne ustawienia ale zrezygnowaƂem KupiƂem adapter USB Baofeng 5VR i CHIRP atomatycznie wprowadziƂ etc
a727469
Maine
I noticed that also and above I suggested he find someone locally who is in a local gmrs group if there is such a thing. Maybe he is just confusing termsđŸ„Ž.
May I suggest the OP look into a real amateur license if he really wants to continue learning in this hobby. While not needed it does help increase one’s basic radio/electronics knowledge without a whole lot of work for the Tech license.
