SevenMaryFour
- Joined
- Dec 22, 2014
- Messages
- 20
I'm glad you brought that up because I thought that might be part of the problem as well. On the Plano/Allen/Wylie/Murphy P25 digital system, I get a full 4 bars on my HomePatrol-1 with my external antenna at comparable distances from the transmitters. Since it's P25 digital, the audio sounds more or less the same regardless. The county's analog system control channel hovers between 2-3 bars (and swings between 0-4 bars on the talk channels). As an experiment, I turned on the attenuator feature last night. The PAWM system stayed strong at 3-4 bars and did seem to remove some of the digital distortion that happens from time to time, but the County system disappeared completely, so I think it's more a weak signal issue than a strong signal issue.Are you sure you aren't getting too much signal? Too much will cause this kind of popping etc.. I know from experience. I thought for the longest time I wasn't getting a good signal. Turns out these scanners aren't great at filtering UHF, thus any amplification of signal just overloads the filters and lets all the crud through.. Try attenuation on your signal and see if it helps. Can you get a signal with no antenna or very little antenna at all? If so, you probably have overload problems.. Example, on my 785D if I have full bars on an 800mhz trunked system, it sounds like crap. If I cut the signal down to about 3 bars, it sounds much better. Hiss in the background, but much much better to listen to. My 668 is really good at attenuation on the systems I listen to. Makes a system that is hard to even listen to, to something that sounds rather good.
Re: the use of an external antenna vs rubber ducky, I do have an RS-800 that I've tried. The PAWM system comes in pretty well on it, but the county system is too weak. With the stock HomePatrol-1 antenna, neither system can be monitored from inside my apartment.
