indiana safe-t
hamiltonfd221
hamilton,ohio
does any one know if franklin county and dearborn county has rebanded or r they with the 866 867 and 868 freqs and if they have whats the new freqs thanks
JStemann
SE Indiana
still running with the old freqs. as of last night for Dearborn co. Can't say about Franklin co., little too far away.
jeff s.
kc8gjh
Bright, Indiana
Dearborn and Franklin County are both using SAFE-T and VHF. Dearborn County uses it full time with the VHF as the simulcast. Franklin County Sheriff uses it full time with Fire/EMS using VHF as dispatch and then usually switching over to SAFE-T. The frequencies in the DB are correct. Check your other post regarding this as I replied with the possible reason you might not be getting SAFE-T in Hamilton
