Indoor antenna for weak signal
jetscanner
So, I have a weak, but mostly consistent, simulcast signal at a certain window. 770Mhz is the CC range. Using the RS 800mhz receiver antenna now.
Obviously, a yagi is the ticket, but I'm hoping for something indoor I can just plop on the windowsill and run the scanner nearby so the sun/window heat doesn't destroy it. Something even BETTER than the RS 800mhz?
There's a lot of interesting antennas out there and was curious if there is anything better than the RS and more focused on 770mhz (or perhaps, something directional that's fairly small)
G7RUX
Have a look at the HB9CV; it’s is a two-element yagi-alike antenna where both elements are driven and so gives directionality similar to a three-element yagi. That should be nice and small and fit on a windowsill with no issues.
