Inside of a Cable Guy's Truck
specman
KG4LJF said:
I understand, if there is a leak, or malfunction, it's his job to repair it. But, I'd prefer the cable guy being honest, and up front with me about it in the first place, and IF he is, then I'd have no problem paying $$ to have the problem fixed.
I agree with what you said, but I should point out that in many areas (mine included) the cabling inside of a house/building is the responsibility of the owner, not the cable company. What this means is that it may NOT be their job to fix items inside your home; although they usually will do so if desired and will bill you accordingly.
Best to check your area to be sure... wasn't too long ago things switched here.
Medford, OR
specman said:
Turn off the cable if they don't do anything about it after a reasonable amount of time.
So for that "reasonable amout of time" everyone else in the neighborhood should have to endure a crappy signal because that one guy did a half assed cable job?
specman
Of course not.. in your scenario something would need to be fixed right away (so "reasonable" might be "hey buddy, that cable needs fixing within the hour!")... but we're talking about something a lot less innocuous here. Anyways, this thread got sidetracked a long time ago...last post for me in here.
Say, that's a nice installation in that truck! :)
irsa
I want to know about the Intermec and the dock. Is it a 700? And does it have an external antennae? I really need one for my 700!
awall
Springfield, Missouri
Hey burner50, Do you have police freq's programmed into your GM300. How many channels is that radio? I have a Kenwood mobile in my work truck and we have 10 different channels we use for the company. The rest of the 99 are all mine to play with as I please. Also I have 2 16 channel GM300's in UHF and 1 32 channel Maxtrac in VHF I use for scanners in my house along with a pro 92 and Icom pcr1000.
burner50
The Third Variable
NC Iowa
Its an intermec 761 Runs off sprint or verizon data systems. No external antenna.
And no...I only have work freqs programmed into the Radio....Wouldnt even know how to program anything else
People,
Cable leakage is a dual-edged sword. You, as a cable subscriber are responsible for everything within the home. The cable company takes care of the drop and the plant itself. If the leakage is coming from within your home, the cable company can fix it upon request, but you are also responsible for it. If you refuse to fix it, you can be disconnected.
Perhaps you should read your subscription agreements. However, if the leakage is coming from the plant, then the cable company needs to fix it and will do so because of the anomalies it causes.
The caveat is that the cable company is responsible for leakage within the entire system, and if the leakage is high enough in signal to be heard from a technician in the street with a detector, then it is high enough to be heard during an FCC leakage flyover. Yes, they fly in airplanes over the cable plant and listen for leakage. This is the reason why they make you fix leaks within your home.
Funny thing is, the FCC is most concerned with CATV leakage because of the interference it can cause to Aviation frequencies. Most leakage detectors are tuned for somewhere between 121.xxx and 125.xxx to recieve signals!
Anyway, if a technician comes to your home and says you have a leak, he or she needs to explain what that means, the charges that could be incurred, and show the user agreement that states the responsibility. I worked for quite a few years in CATV and went out of my way to explain the theory behind what I was doing and have extra copies of subscriber agreements.
So, if you have colored bars to the left side of your TV screen, shadows or ghosts, or white dots floating throughout the screen, you may have a leak somewhere!
