Iowa Statewide Interoperability Communication System (ISICS)
WillB
Henry County
They should be doing their weekly pager test tonight at 7. Curious which talk group they use.
radiowa
I've been up in the Clay County area and it's like a dead zone for ISICS traffic up here. Is there a missing tower from the DB or is it just that quiet?
tfhphoto
Sioux City
All I'm aware of in your area are the Sanborn, Estherville and Storm Lake towers. When I'm in Spencer, I find the Sanborn tower to be the strongest. But - depending on where you are in the county - your mileage will vary. Also, there are no local agencies really using the system up there, except for occasional mutual aid-type traffic. It's mostly highway patrol. Pretty much just that quiet.
radiowa
It'll be interesting to see what happens as Dickinson County (just north of Clay) will be joining the ISICS and I don't believe there are any current towers in the county
jvradenburg
Somewhere, USA
Looks like I'm going to have to get a new scanner to pick up this digital stuff for kill tech at least providing they're not encrypted
tfhphoto
Sioux City
Any thoughts as to the identity of TGID 1? It pops up very occasionally on the Starcomm towers. Traffic is always super short. Yesterday I caught what I assumed to be a dispatcher contacting a Des Moines International firefighter.
Iowa
From what I've been told, you don't use TGID #1. It's the default TGID in a radio when you add a new TG in the programming...so if there was traffic on it, it was probably a improperly programmed radio.
mws72
Quad-Cities (IA-IL) USA
I been hearing comms on TG4300. This is listed in the database as ArNG Davenport. But I have been hearing the units referring it to as Statewide.
radioboy75
Rock Rapids, Iowa
It's official. Lyon County will be switching SO traffic to ISICS. The sheriff says the new dispatch console is already in, but they're waiting on vehicular repeaters to be available before they put ISICS radios in their patrol cars.
timkilbride
Linn Co Iowa
Changes have been applied to the DB.
I have noticed they have been flying this week.
Tim
tfhphoto
Sioux City
Will the county be adding a couple of new towers, or do they think the one in Rock Rapids will be enough?
MCWKen
Clinton, IA
Tim
Davenport is Shop 4, and they update fligh status with Shop 4 via ISICS. It can vary, but it is quite busy at times depending on what flights are out there. I have heard flights well into Minnesota and IL update status on ISICS from time to time.
Especially interesting to note, when they have fly-by's for various events, you will hear them set it up on ISICS TG 4300. So I keep 4300 on priority 3.
Also note, ISICS talkgroups are not a replacement for communications in drills inside such places as the Crypt MOA. Those communications are still on Uniform (UHF). Reason being they must to keep in contact with ATC to activate and clear those MOAs.
mws72
Actually Davenport is Shop 3 as posted on the sign at the Airport
mws72
I know Davenport is Shop #3 and Shop #4 is or was Council Bluffs. I am guessing Boone is Shop #1 and Waterloo Shop #2?
radioboy75
Rock Rapids, Iowa
Does anybody monitor the Sanborn tower regularly? For some reason, my remote scanner at Sheldon hasn't been picking it up lately. When I punch it in, in direct frequency mode, it does show some signal, but it's quite low compared to what it has been. Nothing else seems to have changed...
MCWKen
Clinton, IA
I noted that Clinton PD now has two fully encrypted TG's, 23507 and 23506. RID's were consistent with normal PD radios. Also, I noted that a fire department (not sure if it was county or City) was using 23515 for drills.
Just FYI.
