IP site connect
nguyenluan308
I have a problem in IP site connect System
I have 2 site, each site have 1 repeater SLR5300
Each site run in Conventional mode normaly
But in Ip site Connect mode have problem: 2 repeater linked but RX mobile radio not audio, although RX led blink .!!!
Help me!!!!!
com501
Does RDAC work and show both sites? Are you using the Internet for the link by chance? (A very poor idea).
nguyenluan308
REEEEE...
My system use WAN network in a factory. I checked ping 2 site normaly.
For debug, I used switch connect 2 repeater but not effective.
Then I use crossover cable connect direct 2 repeater, but not effective :(
No way:(:(:(
Firebuff880
Boynton Beach, FL
Maybe, go back to the manual an reread the section on configuration for IPSITE Connect, or get the dealer you purchased the system from to come in an trouble shoot. They should be happy to if you have a service contract, or for time an materials if you do not.
com501
The manual cautions that you should have NO OTHER devices on your network, and not to share a common IP range with any other devices. If you have routers or switches between your machines, you need to make sure that any firewalls do not block the UDP traffic between your devices.
Project25_MASTR
Millennial Graying OBT Guy
Texas
And/or build routing tables.
Is this an analog system or digital?
vans113
Tennessee
Have you assigned everything a static I.P ? Have you made one repeater a master repeater? Told the other repeater what the I.p of the master is? Built the site list in the master repeater? I can go on. P.M me if you would like or post the code plugs here and I'll be happy to look it over.
