Is DSD + decoding encrypted group calls apco 25
RayAir
You need to look at what DSD+ is telling you. When you hit it with a TDMA transmission from your DMR radio, DSD+ isn't decoding anything due to poor syncing. You can probably clean it up by locking the baud rate and protocol with the -fr command line switch.
Typical taxi company setup. Dispatcher (RID 100) broadcasts to all drivers, drivers reply only to the dispatcher. You should upload a raw audio recording.
Everything is showing as BP now? I don't know if that is accurate but my raw audio samples are wav. files and I cant upload them on here. I can email them to you if you want to PM me your email.
Or send it to me: pilot.rg77@gmail.com
sammy3418
That looks like a system I have been trying to listen to to..... Basic Privacy seems to be the norm now.. Unless someone can make an addon that goes through the 256 possible codes. I am not a coder so I don't know how to write addons Enhanced privacy we can forget, but BP is doable
RayAir
Can you zip them up and stick them on Zippyshare.com? It's pretty simple to do.
I just looked at zippyshare. I zipped one of my wav files and I'll get it on there today.
Thanks.
I have another system I'm looking at in a different part of the state and I'll send you a wav from it too.
RayAir
I improved my antenna location to get less errors in my decodes and those BP's changed to EP's for the most part.
If the signal isn't really clean it looks like DSD confuses BP and EP. I had this issue before.
I have an SL 7550 that is on a system back east and it is programming locked (vendor locked). I don't have Motorola CPS to overwrite anyway.
Otherwise you can verify BP or EP with a real radio.
slicerwizard
Toronto, Ontario
-fr -dr4 -dh1 -ds65 -dd45 cleans up the decoding enough for DSD+ to detect/process the PI headers on every call. So yeah, everyone's using EP.
