Is IP over simplex DMR possible with NX-5000 series?
rural_radio
¿Por qué no Ø?
GA
I saw a demo of Motorola XPR series handhelds and mobiles being used as (4800bps) ethernet adapters for use out of mobile phone coverage or in the wake of a hurricane when cell towers were down. The Moto dealer kept pushing the fact that you could send data from any app as long as you understood the 4800bps speed limitations.
Does Kenwood offer anything like this? My local dealer didn't seem to think it was possible, but I know I'm going to get asked about it by everyone else who saw the Moto demo.
rural_radio
¿Por qué no Ø?
GA
I'd have to dig into the manuals, but I know it's possible with NXDN. 4800bps for 6.25KHz channels and 9600bps for 12.5KHz channels.
Thanks, mmckenna!
NXDN would be fine, as our radios are currently programmed for P25 and NXDN. Any idea what options or cables I would need, or what Kenwood calls it in the manuals?
The only mention I could find was talking about integrating with dispatch consoles, but it wasn't specific about how to do it.
bdbrennan
GA
No, the NX-5000s do not support IP bearer services. No BT PAN or LAN connections to the radios. Transparent data is for serial data connections.
rural_radio
¿Por qué no Ø?
GA
bdbrennan,
It's a shame it can't do native IP, but I'm hoping I'll be able to make a PPP connection, or depending on the use case, use socat to redirect a single port over the serial, so long as I can send arbitrary data.
If anyone's already using this feature, I'd like to hear about it.
bdbrennan,
I've used it for point to point data. It works.
No, it's not native IP, but that's easy enough to convert.
rural_radio
¿Por qué no Ø?
GA
While I'm waiting on my dealer to get back with me, I've tried it out with a couple of portables NX-5200, but I'm not having any luck getting them to transmit. I know I must be missing something obvious.
In KPG-D1N, I've assigned the com port (COM Port 0 in the case of the portables) the function "Transparent (Digital)", as normal polarity, 1 stop bit, 9600 baud, and no flow control.
I set both radios to a NXDN conventional channel. When I connect the data cable to the radio, I'm able to use PuTTY to connect to the serial port, and the TX light on my data cable flashes whenever I press a key, but the radio never transmits anything.
I tried the same thing with a Raspberry Pi, both using socat and just using the command line to echo strings of text to ttyUSB0, and while I don't get serial port errors, the radio never seems to transmit.
I don't see anything in the Zone or Channel settings that look likes it would need to be set. Can anyone suggest anything else to check?
R22Beta
This is a long shot, but I noticed when I have option checked in KPG-D1N "Transmit Clear Alert Tone" (Under Encryption) then when I key the transmitter I get a single flash on the TX LED and then it goes out and the radio stops transmitting.
I rebuilt a program from scratch enabling options one at a time until I recreated the error to figure that out.
Maybe start from scratch and enable options one at a time until you can recreate the transmitting issue?
kd4efm
Florida
I use D-RATS to send data.
I proved this concept during the 1st year of NXDN, and send files and text over NXDN.
Might crawl Yahoo groups for my article I did back 12 years ago with an NX-800, over IP to K1IFF in
CT. So, I do know it will send data over IP from site to site.
Have I done it since then, no, but was pretty straight forward.
Transparent mode yes, and using the DB25 to DB9 and win7 running D-Rats. (Yes I know its for D-Star, but it works)
