Is the pro97 programming protocol documented
enine
I've tried the demo of win97 and its too annoying as it keep swanting to change settings that I don't tell it to change, I just want to plug in some frequencies. Plus its closed source and limited to one OS. I'm wondering if the protocol is published so I can just dump the date and edit what I want then upload it again.
On another similar note, has anyone taken apart the cable and stuffed it inside the scanner then mounted a USB port on the side so you only have toi use a standard USB cable?
DaveIN
Founders Curmudgen
West Michigan
Nope, Radio Shack has yet to publish any protocol for their scanners.
Not enough room in the scanner for the size of the board as it is configured.
