Is there such an anamial ???
tom3000
Maryland
2 questions for you all and if I am in the wrong area please let me know and I will relocate this text.
I am living in Maryland and travel to the surrounding states. I am looking for a scanner that will receive all the currently active trunking systems in WVA, VA, DE, PA and or course MD. Is there one scanner that will accomplish this feat if so which one?
Question 2 Is there a PC card or PC add on scanner that will accomplish this and are they worth the money or do they suffer from PC EMI?
Thanks much
Tom Anderson
tjander@verizon.net
BoxAlarm187
Level 6 RR Member (Since 1998)
Old Dominion
First, welcome to RadioReference. I hope we'll be able to help you.
Secondly, you didn't say if you want mobile or handheld, but to receive "all" of the trunked systems, you'll need a digital capable scanner, such as the Uniden 396T/996T or Radio Shack Pro-96/Pro-2096. The 996T just came out a few weeks ago, and is the nicest scanner out there to date. As someone who travels a lot, you might be interested in this scanner, as you can hook a GPS unit to it and it can automatically listen to systems as you travel from one area to another.
Keep in mind that there are trunking systems out there that no scanner can receive or trunk (ProVoice, OpenSky, etc), but these are in the minority.
There are PC-based receivers, but they won't do trunking like you want to do.
Let us know what else you need...
tom3000
Maryland
OK on the PC based units, that what I though the answer would be.
I will look into the ones you mentioned. I under stand that some trunked system can not be recovered but if I can get the vast majority I will be happy. I am looking for a base unit. hand helds are too small for my fat fingers and i will just lay it down some place and forget it.
I also am a tinkerer that is I like to do mods and improvements and base stations seem to allow more of that type of activities. Thanks for the info again
