IWN National Capital Region System Changes
BM82557
Berkeley Co WV
Just a better screen grab to show the difference between an typical P25 CC on the left (171.5375 site 1.88) and a non-decodable P25 CC on the right (171.6125 site 1.96) --
maus92
The OP
The one on the left looks like a smartnet control channel. In any event, it's weaker than the signal on the right.
dlwtrunked
Paris Mtn. was (is?) transmitting that signal simultaneously on 168.4875, 170.3875, 170.9125, and 171.6125--so I do not think we can label it as a control channel transmission. At the same time, nearby Bull Run was using the same 171.6125 as its normal control channel! I think this is a test signal.
maus92
The OP
Right - it's possible that 171.6125 is being used for coverage testing. I saw something similar last week in the PG area, and I've seen it during MontCo PA coverage testing - the waveform looks P25, decodes as P25, but no control channel data. I have a document somewhere that describes the process and the signal that is typically used in coverage testing Motorola systems.
BM82557
Berkeley Co WV
Here I posted my P25Data file awhile back and forgot to go back and cross-check it out! If I had done that I would have realized that all 4 freqs are on the same site so you guys are most likely correct as to it being a test signal. Sorry for the confusion I have caused.
maus92
The OP
Here's my contribution to MontCo PA thread that talked about the signal, lol:
BM82557
Berkeley Co WV
Finally had a chance to look at this some more, from the received signal strength at my location it appears 170.9125 is not at the same location as 168.4875, 170.3875 and 171.6125 but it doesn't change the fact that all 4 are transmitting a test signal --
dlwtrunked
I was at the transmitter site--shouting distance to the tower. I had to back off down the mountain as it swamped the receiver. They were all from there but you are correct, the signal levels were not equal. It is also possible that making measurements at a different time might have see different sites. Real odd how 171.6125 was coming from there and Bull Run was using that as its control at the same time. I checked signal level at each while there rather than just the sound. Note that the frequencies previously know for the site are 170.625, 170.8375, and 170.9125 leaving the 170.9125 the only one in both lists--maybe it is an older lower powered transmitter or the others were set to new different frequencies and power increased (or forgottne to turn down) when doing that. Would be worth watching--I cannot see the site from home.
palmerjrusa
Frederick
Not able to monitor the Fort Detrick channels any more on JCNR here in Frederick.
Does anyone know what's happening?
maus92
The OP
Yes.
I'll be in Frederick tomorrow - I'll check the status of the system.
