Jacksonville Naval Air Station
pawsrock
Jacksonville Fl.
I have a pro 2096 and a larsen Tri-Band antenna in my attic. I have program all of the freq and talkgroups for Jacksonville N.A.S. "I am not hearing anything," so is this just very quiet are do I need to do something else.
Ron Fone
Home
ChrisP
Portland, OR
Ron Fone
Home
If you are referring to the 380 MHz DoD trunked system sites in Jacksonville, the 2096 will not trunk-track those systems. You can program them conventionally and listen that way if you choose, but otherwise you will need to upgrade to a PSR-500, PSR-600, 396 or 996 scanner...
- Chris
ChrisP
Portland, OR
Also, if you don't have it already, you will need the WIN96 software to unlock the extended frequencies. Out of the box, the 2096 will not accept the 380 MHz channels in it's programming...
- Chris
