Jeep JL mount for SDS100
gatsat
I am looking for a solid mount for an SDS100 in my Jeep JL.
I have an overhead molle mount that spans from the windshield to the roll-bar, directly over the center console. I have DC power and antenna coax cables run to the molle panel that I use for various radios. I would like a mount for this location that holds the SDS100 secure. I am fine of the display faces straight down or if the mount articulates, just so long as the scanner does not pop out of the mount during turbulence.
Thanks in advance!
jeepsandradios
East of the Mississippi
Think it may be hard to find something. When I had molle in the JK I used Velcro straps around a small radio so maybe try the same ? That should hold it secure. Mine was 2" velcro that screwed into a small plate behind the molle.
nc6a
Check here;
gatsat
Was your molle made of fabric or a solid material? Mine is metal, cut in a molle pattern. I should have clarified that in my original post.
gatsat
Check here;
Thanks! The Lido products look very nice.
GlobalNorth
Fort Misery
Reconsider metal mounts overhead. I've seen a few fatal accidents and plenty of head trauma accident when the skull gets thrown into unyielding brackets, mounts, and gear. It can also happen off road when traversing rough terrain.
If you go with Lido gear, I personally use it in my JK and recommend them.
gatsat
That is some food for thought! Where are your mounts located in your JK? Are they permanent mounts? Thanks
jeepsandradios
Mine was a metal molle panel. Basically aluminum full of 1"x1" holes I guess. Only used it for one handheld. Other radios used the Panavise Dash mount that goes behind radio and magnetic mic to my APX radio HHCH.
gatsat
Panavise makes one to go behind the radio - https://www.panavise.com/pdf_indash/75122-621.pdf
Personally in my JT I used the ball mount on the grab handle from CMM offroad - Gladiator JT Grab Bar Ball Mount
Thanks, this is very helpful!
