yankees6161
I will be installing my antenna out side this spring, will be using lmr400 cable. Should I use a lighter wight jumper cable to go in to the scanner or is it he 536 bnc connector strong enough to support the lmr400? If you suggest a jumper cable what cable would you use? I was thinking of something like a 4 foot jumper using 195 or 240 low loss cable
