Jumper cable
jazzboypro
Laval
Hello all,
I need some jumper cables, the jumper cables will be connected to LMR400 on one end and to the radio at the other end. The cables will 1 foot long it will be used in a receive only application. I wend to wify expert to create the custom cable. They have a lot of cable type available in the LMR series. Would LMR240 be adequate ? any suggestion on the proper type of cable for jumper?
73
VA2FCS
prcguy
If they are only a foot long you could go with LMR195/200 series. Personally I would go with a good RG-58 with stranded center conductor, its more flexible and the loss in one foot is nothing to worry about.
Hello all,
73
VA2FCS
jazzboypro
Laval
Thanks, i will also eventually need jumper cables in a transmit application at no more than 100 watts, would LMR195/200/RG-58 Still be ok ?
prcguy
Should be no problem at 100w. A lot of RG-58 brands are rated to 1kW up to 30Mhz and lower power at higher frequencies. A cheap Chinese brand may not do well at those power levels but anything from a company like Belden, Commscope, Alpha, Times, Carol, etc, should be fine.
jazzboypro
Laval
Thanks for the info
