I don't have much luck with KCK, or JOCO. I am in LV. I can get Platte Co. really good as their tower is in LV.I tried to search the forum but can't find anything recent.
Is KCK fire encrypted or should I be able to pick it up?
I put the frequencies in my scanner but I'm not picking anything up. Using a handheld in Leavenworth County.
Doesn't the Pro-96 do P25? There are other radios other than Uniden that would pick up KSICS or Marrs. I have a BlueTail Tech P25RX that is way cheaper than most of the other brands and does an incredible job.I'm using an old Radio Shack Pro 96.
I'm using an old Radio Shack Pro 96. The only thing I can pick up is Leavenworth fire dispatch on 154.38500.
I'm going to have to break down and buy a new Uniden one of these days.
Your closest tower is in Platte Co, that's why you can hear them so easily.
If the Pro-96 does not receive the MARRS P25 system, adjusting VR4 inside the scanner may help. It is labelled on the circuit board. Do you have programming software and a cable for your Pro-96? I use Butel ARC96 software. Did you download and install the Uniden Sentinel software for your SDS100? BCDx36HPSentinel < UnidenMan4 < TWiki You will need Sentinel to update the database and firmware and create favorites lists. Which systems and agencies would you like to monitor with your SDS100?I'll play with the Pro 96 some still.
