Kenwood NX-5300 Tone Transmit
lnicholls104
Nicholls
I am looking to see If I am able to transmit tone on a channel using a Kenwood NX-5300. I know on Motorola APX series I can setup a Quick-CAll II setting where when i press a button it will transmit a set of tones over the selected channel that I had programmed into the radio. I am trying to do that on a Kenwood NX-5300. Is that possible. TIA
lnicholls104
Nicholls
Should be under the 2-tone settings, make sure you have it added to the menu as well.
I believe I have it setup. I entered the tones under the “Encode”. I set a button on the front for the “2-tone”. Click the button and I can hear the tones on my radio. Cant hear the tones on a different radio. Something I did wrong?
Are you sending the 2 tone with the correct QT/DQT?
Does the other radio have the correct QT/DQT set?
Does it come through if you open the squelch on the other radio?
EWC_BDN
Does the Tx light come on while you hear the tones after pressing the button?
