Kenwood nx700 audio issue
K2ERI
SC
I have a kenwood nx709 in remote mount setup it’s been like this for 7 years worked great all of a sudden the speaker no longer seems to work even if I press buttons or anything but worked fine for years all up till yesterday, the only thing I’ve noticed is that I usually leave it at 10-11 for volume but have been turning it up to 14-16 the last few days because it seemed hard to hear. I’m curious if the speaker finally went out
Arizona
I am assuming you are using the speaker in the control head? Is it possible it has received any damage? Have you tried an external speaker using the 3.5 jack or into a KAP-2? Otherwise I would agree with kd4efm.
K2ERI
SC
I plugged a set of cheap headphoness into the jack and heard the noaa band on one of the earbuds
Your audio amp is probably good, then, unless it's not able to drive anything bigger than a pair of ear buds. If you have an external speaker, try that.
Probably check all your cable connections for the remote head, check the speaker in the control head, etc.
K2ERI
SC
I checked the speaker wire inside the remote head and it’s solid only thing I noticed was where the speaker is the cone is in good shape but the large metal back that’s round seems loose and can be moved slightly
That's the magnet for the speaker and if it's loose, that's your issue.
Kenwood part number T07-0757-35 $35 list new from Kenwood.
K2ERI
SC
Happen to have a link too that part can’t seem to locate it
Thank you
Thank you
It's a Kenwood part number, so they only way to get it using that number is to contact your local Kenwood dealer and have them order it for you.
It's probably a commonly available part, if you could work backwards off what you have.
