Kern Canyon IC
tomasG
Lancaster, CA
This fire is taking off at near 1000 acres already. I have the standard Kern fire channels, but I know that they are on simplex tacs somewhere. Can anyone tell me where? I have a yagi pointed right at them and I'm hearing wiffs of si9mplex on the output if the repeater. Also White 1 now VFire-???
Eng74
Kern County, CA
Command is Kern 5, Tacs are V Fire 22, V Fire 23, White 1. Unless you are in the area you will not get the Tac's. They did have Tanker 910 the DC -10 yesterday, not sure if it will be back today.
tomasG
Lancaster, CA
But why? I can hear far better than the multi-agency scanner feed. I am using a yagi pointed right at the fire and I am hearing excellent comms. But the frequencies I have are those from the database here and I know that there are additional. I have added VFIRExx and VTACxx. Some traffic on VFIRE21 which I guess is the old White 1?
Thank you to the person that feeds the feed referenced above but with the frequencies offered I can provide a better feed. I'm in Lancaster and can put up a feed of Radio Reference allows a temporary feed. It sounds like I have most of them already.
Who has this now? Is it still Kern or did CDF take it over?
tomasG
Lancaster, CA
Alpha 910 is 30 miles out and loaded for a drop. I'm hearing this on my side. This is what I currently have:
Code:
Channel	Frequency	Tone	Text Tag
451	153.785	167.9	KRN1
452	155.88	167.9	KRN2
453	155.625	167.9	KRN3
454	154.86	167.9	KRN4
455	151.1	167.9	KRN5
456	151.475	OFF	TAC 2C
457	158.74	OFF	TAC 3C
458	159.475	OFF	TAC 4C
459	151.14	OFF	TAC 5C
460	155.755	OFF	TAC 6C
461	453.2625	OFF	KernCyn CB#2
462	151.22	OFF	A2G
463	151.31	OFF	A/G
464	151.22	OFF	A/G
465	135.975	OFF	TANKER BASE
466	154.28	OFF	VFIRE 21
467	154.265	OFF	VFIRE 22
468	154.295	OFF	VFIRE 23
469	42.6	146.2	CHP FT. TEJON
470	154.16	OFF	OES 1
471	154.22	OFF	OES 2
472	166.875	OFF	AIR
473	167.95	OFF	BLM AIR
Eng74
Kern County, CA
The IC is still a KCFD BC. The command channel Kern 5 151.1000 is the only ne that is on the repeater. In Lancaster depending on where you are you can get all of the KCFD channels very good. You can even get Kern 4 which is not supposed to be on the east side. All of the Tac channels are line of site so if someone is on top of a hill you can get them.
tomasG
Lancaster, CA
I can hear all of the dispatch channels on the Austin Ferret that until now I thought was a waste of money. A friend of mine made an excellent galvanized steel bracket that attaches it to my DirecTV dish mount prebuilt into the house. That suckers stands straight up into our high winds.
But I also have a log periodic yagi covering 134-174MHz with 6-9dBd gain. It is very effective. Aimed at the fire across the valley I am hearing simplex comms.
So I guess that this isn't a CDF fire as I had read on Wildlandfire.com.
Primary air-ground is on 151.3100. 135.975 tanker base and 166.875 air attack are all busy.
Eng74
Kern County, CA
Yeah it is an air show and crews/dozers fire. Most of the rolling stock is for structure protection. It is not in the SRA land getting near some BLM if I heard right. BLM will be shutting some trails down near Rosamond.
K6CDO
Hanover Co. VA
... Some traffic on VFIRE21 which I guess is the old White 1?
The fire should be using White 1 (not VFIRE21), as that channel has not been narrowbanded yet (and won't be until next spring at the earliest), as per the State plan (CalEMA Fire & Rescue Bulletin 28).
Uplink
Los Angeles County
Care to share a pic of your DirecTV mount? Sounds like an awesome setup :)
BlueZebra
California
I believe the defined use of White 1 is not as a Tac, but as a mutual aid, and mutual aid command frequency.
PJH
....and you use the best available channel that will get everyone on the same page....
scanfan22
North Hollywood CA
Any chance any one here might be willing to feed all the Kern County dispatch channels?
tomasG
Lancaster, CA
I just got in from work and it seems that they've left Kern frequencies. I am not hearing anything at all and I had this quite well yesterday. Would someone please share the comm plan so I can put a stream up for everyone to listen?
