Do modern day transceivers have a fail proof mechanism to ensure damage doesn’t occur when you key up with a lousy SWR? I am specifically interested in how the Yaesu 991a handles this. I do not have an external antenna tester or tuner. Am I correct that the general process is:
- Set mode to AM and power to minimum on an unused frequency
- Press tuner until internal antenna tuner adjusts
- Key up briefly and look at SWR on the meter
- If under about 2.5 it’s ok to use?
