KG-UV8D question/help
bharvey2
I'm not sure what cable you have so I wouldn't know how to go about obtaining the drivers. However, if the cable you have works for the Baofeng, I think it should work fine with the Wouxun. I use the sames cable for each interchangeably.
WyoDuner
Las Vegas, NV
I have this radio, and have found a serious problem. I bought it for a backup to my mobile, but it does not hold a charge. Both batteries I have drain from full charge to about 7 volts in 2 weeks. I suspect something is always drawing current, as the second battery was purchased separately and it is not likely a battery problem.
Mine does the exact same thing. Pisses me off. I agree, there is some draw on the battery when off. Battery seems fine and lasts a long time but drains when sitting for long periods.
wd9ewk
Arizona USA
This appears to be a Wouxun "feature" - battery packs that are drained when on the radio, even when the radio is powered off. If I remove the pack from the radio for a few days and put it back on the radio, the pack holds its charge. This "feature" is also present on the newer KG-UV9D and its 7.4V/2000mAh packs.
CPerk
King William, Virginia
Amy where on radio or software it self or chirp you can block option of blocking transmit on a frequency? Like ex 155.8350 I just want listen but not transmit, and how you do you alpha tags from radio IF software doest work I been watching videos I see how add chanel but don't understand how add alpha tag then make it show up instead of frequency
CPerk
Any where on radio or software it self or chirp you can block option of blocking transmit on a frequency? Like ex 155.8350 I just want listen but not transmit, and how you do you alpha tags from radio IF software doest work I been watching videos I see how add chanel but don't understand how add alpha tag then make it show up instead of frequency
BHinAZ
Arizona
CPerk - Programming the radio allows for a receive frequency and a transmit frequency. If you are programming a channel where you only have monitoring privileges, not transmit, (i.e.local sheriff), then just enter the receive frequency and leave the transmit frequency field blank. Once programmed, if you try to transmit on that channel, the radio will return a loud error beep to let you know it did not transmit. I also set the power to low on these monitor only channels just as a matter of practice.
Another example of monitor only channels are those with a continuing broadcast, such as the NOA weather frequencies. I have entered all of them just as described above, only entering the monitoring frequency (i.e. 162,400 or 162,550, etc) in the receive field and leave the transmit field blank. .
If you are programming for a simplex frequency on which you want to transmit, such as the VHF Call frequency of 146.520, then you must enter 146,520 twice, once in the receive field and once in the transmit field.
If you are programming a repeater, then you must enter a different receive frequency and a transmit frequency. An example in the two meter ham band would be 146.700 for the receive frequency and 146.100 for the transmit frequency. The software will automatically populate the transmit field once a receive frequency is entered. In my case, it is the same frequency as the receive value. I then manually change the transmit value if it is a repeater channel being programmed.
teufler
ST PETERS, MISSOURI
with Chirp, you have the radio file displayed, go to duplex column, and change offset to none. you then have a receive only frequency. Wouxun software, I think you leave the transmit frequency blank.
mshreves
Alpine, CA
Battery Drain
My Radio does the same thing! With both batteries....what is the solution?
