- Joined
- Dec 19, 2002
- Messages
- 2,631
- Reaction score
- 1,465
I'm an old man. I have been a shortwave listener since the early 1960s. My main hobby these days is restoring antique radios. Some of you may know me from the Philco Phorum where I have been active for years. I was reading a thread about Genesis Communications on 4.84 MHZ. Someone made a reply that people don't use Mhz any more, and just use Khz. They should speak for themselves. I actually go back to the days when we used kiloCYCLES, Kc for standard broadcast AM (540-1600 Kc) and megaCYCLES, Mc for shortwave. Then the term HERTZ began to be used instead of cycles per second, so things changed to kilohertz and megahertz. This new shift to using only kilohertz seems to have come about with digital tuning, and reflects the numbers which a person must punch in to the keypad to tune to the station. That's fine. If you like to call it that, I am bright enough to understand you; but please don't impose your own preference on everybody. To call 4.84 Mc "4.84 Mhz" is perfectly understandable to anybody but the most obtuse beginner in shortwave listening, and referring to that frequency as "4840 Khz" , while also technically correct, actually sounds peculiar to those of us who have been around the hobby for much longer than most of you have been alive.
Gads..."megahertz" and "kilohertz" are the accepted terms today. Just like saying that it is the year "2021", "mc" and "kc" are *long" outdated and contrary to current international standards. Back then it was actually "kilocycles per second", or "kc/s", and "megacycles per second", or "Mc/s" with leaving off the "per second" just considered wrong (as it is) in the circles I move in. By the way,- the correct abbreviations are "kHz" and "MHz" not any of the above that you gave ("MHZ" or "KHz") and it does make a difference. "Hz" because it is name after a proper name" and never the capitol "K" for "kilo" because "K" means Kelvin units of temperature. Saying "mhz" as seen often on RR is even worse ("m" stands for ".001" not "1000000", which is 1000000. This is not being picky, it is being right. (By the way, it is wrong to say "degrees Kelvin" as just "Kelvin" is correct.) Arguments to "preference" or "hobby" are not an excuse to be wrong or out-dated and even make it hard to read. And I also started listening in 1960's. I have been an editor of several publications (hobby and technical). Any of those errors above would have led to rejections for re-write. Sorry if this sounds very negative, but being correct is a good thing to be.
