Kinnelon System
RocketNJ
Pequannock, NJ
I know this because there is other equipment at the site in addition to Kinnelon and I was directly involved with antenna placement on the tank.
The antennas on top of the tank are NOT Kinnelon's. Please don't question me on this.
It is not the black tank you see when driving up to Kinnelon from Boonton. I am talking about their furthest east site which is in the development right up above the ridge just west of 287 as you drive through Kinnelon.
RocketNJ
Pequannock, NJ
And to add one more thing, the coax used is not the best choice for UHF.
K2NEC
5F6
I know exactly what site you are talking about because I've been to the site before. There are antennas on top of the water tower that would have coverage east actually. Otherwise, I didn't see any antennas on the side of the water tower.
How would one send a PM to @GTR8000 ?
EDIT:
RocketNJ
Pequannock, NJ
The antennas you show are a quad exposed dipole and a tri exposed dipole, both of which are County antennas. The Kinnelon antennas are mounted on the side of the water tank on the ladder going up the tank, not in view in your picture. Also the County antennas use 1 5/8" cables and 7/8" cables which Kinnelon uses combo of 9913 and 1/2".
RocketNJ
Pequannock, NJ
I decided to retest Kinnelon from Pompton Plains on my SDS200 today. I loaded all sites.
Denise Drive, 453.5125 is coming in and perfectly readable on an indoor unity gain UHF antenna. (not the telescopic antenna). So from the last time I tried to monitor their system to now, I can now hear them. Same setup about a year ago was no-go so maybe they had a bad antenna or cable at Denise that was repaired?
Sal, try Denise Drive, 453.5125. You can use Sentinel to load Kinnelon from Radio Reference then lockout the sites except Denise. If you need help loading your scanner PM me direct.
Dave, I stand corrected. Now Kinnelon has better coverage east then it did a year ago. A year ago they were unable to be copied in Pompton Plains from any site.
K2NEC
5F6
Believe it or not there are spots outside of town that I can reach the Kinnelon system better than I can our PD repeater. Lincoln Road has fantastic coverage to the north and east and even when I was down in Denville I was able to pick them up. I'm not sure what you were experiencing beforehand but if you say it's better now, it's possible something changed. I found the antennas you were referencing and was getting a -35 db on them so they are definitely the ones. Maybe you can see if something changed on them since last you saw.
Salvatorejrc
@RocketNJ
I successfully received from the Elizabeth site just now.
I've been up Elizabeth Dr. but I've never actually seen the site, do you know exactly where it is?
K2NEC
5F6
Funny enough, the repeater is located in a cabinet on the side of the road at the end of Elizabeth drive.
slingshot202
New Jersey
Interesting, I might just be to far in Essex County, but never hear them. I have the SDS200 with DMR. I have DMR in my truck, I should put them in there for when I ride north on 287.
NParkNJ
On the Road
Northern NJ
plenty more to listen to with DMR up here now.
Pequannock, and also Bloomingdale are DMR. I suggest popping them in as just the frequency and CC. Works perfectly for me on my 996p2.
slingshot202
New Jersey
I am in Essex County - I have them in, but I have not heard Bloomingdale. I do listen to Pequannock and Rockaway Twsp. I will try doing just the CC and see if I catch them.
K2NEC
5F6
Don't bother trying to listen to bloomingdale. They truly don't have out of town coverage. (They barely have in town coverage :censored:)
slingshot202
New Jersey
LOL - that explains that! I hear them on VHF or UHF, I forget, but I have had nothing on DMR.
NParkNJ
On the Road
Northern NJ
compared to pequannock, definitely not. I can hear them in Ringwood and only Wanaque and parts of Pompton. Other than that, I don't think so....
RocketNJ
Pequannock, NJ
Bloomingdale is located in a valley and the hill in Kinnelon blocks coverage south.
K2NEC
5F6
And the sites aren't exactly in great locations
RocketNJ
Pequannock, NJ
When they were on low band the sites were fine. Now they need HAAT (height above average terrain).
